You could use windows 7, this Motherboard supports up to 2 gigs of RAM, Windows 7 can run with a minimum of 1 gig of RAM. 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor. 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit). 16 GB available hard disk space (32-bit) or 20 GB (64-bit). DirectX 9 graphics device with WDDM 1.0 or higher driver.
If you want to run Windows 7 on your PC, here's what it takes:
Yes, its supported by windows 7.
but need more setting to make it fast. maybe tune up utility will help increase the performance.
help me by rate my answer.
Yes
MSI K9MM-V Motherboard Specifications
Part # K9MM-V
Manufacturer MSI
Manufacturer Part # K9MM-V
Product Type Motherboard
Form Factor Micro ATX
Chipset Type VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support Dual Core
Max Bus Speed 800 MHz
Processor Socket Type 0 ( 1 ) - Socket AM2
Compatible Processors Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
64 Bit Processor Compatibility Yes
Multi Core Support Dual-Core
Memory Supported RAM Technology DDR II SDRAM
RAM Installed 0 MB / 2 GB (max)
Supported RAM Speed PC2-4300, PC2-6400, PC2-5300
RAM Features Two DDR Channels
Video Graphics Controller VIA UniChrome Pro K8M800
Video Memory Shared video memory (UMA)
Audio Audio Output Sound Card
Signal Processor Intel HD Audio
Audio Codec Realtek ALC655
Sound Output Mode 5.1 channel surround
Networking Network adapter - Realtek RTL8201CL - Ethernet, Fast Ethernet
Expansion / Connectivity Expansion Slots Total (Free) 1 processor - Socket AM2
2 memory ( 1.8 V ) - DIMM 240-pin
1 AGP 8x
3 PCI ( 3.3 V/ 5 V )
Storage Interfaces ATA-133 - connector(s): 1 x 40pin IDC - 2 device(s)
Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 2 device(s) - RAID 0 / RAID 1
Interfaces 1 x storage - floppy interface - 34 pin IDC
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
2 x serial - RS-232 - 9 pin D-Sub (DB-9)
4 x Hi-Speed USB - 4 pin USB Type A
1 x audio - SPDIF output - RCA
1 x audio - SPDIF output - TOS Link
1 x audio - line-out (rear) - mini-phone 3.5 mm
1 x audio - line-out (center/subwoofer) - mini-phone 3.5 mm
1 x audio - line-out - mini-phone stereo 3.5 mm
1 x audio - line-in - mini-phone stereo 3.5 mm
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Additional Connectors 4 x Hi-Speed USB
Compliant Standards Plug and Play, RoHS
MSI K9MM-V Summary
Yes you can run Windows 7 on a MSI k9MM-V motherboard.
This motherboard supports Vista x64 so Windows 7 should also be OK.
Download drivers if needed from here:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver
