Lexmark X7675 Wireless All-in-One Printer Logo
Posted on Mar 06, 2011
I have a lexmark x7675, when ever I try to copy or print anything, the paper feed but it then stop and the printer says that there is a paper jammed, but there isn't any. I tried several times and the paper always stop and says that there is a paper jammed. I can't fix the problem.
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1485
Points
20
You have to open up the printer using a every day Phillips screw driver, once you have done that you either need to rotate the roller by hand or look for something stuck in rollers that you cant see under normal circumstances
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
When using the printing function my lexmark won't feed the paper through - it sounds like it's trying to grab the paper but doesn't.
on these you have to have about 10 to 15 pages loaded for the weight to grab it
also the smallest peice of paper stuck dep in it will cause this get a compresser and blow it out be carefull not to put full pressure on it or you will blow it away
My Lexmark X7675 is pulling the paper to the left when printing causing the paper to Jam. How do I fix this?
Hello sir; Check the paper tray at the bottom there should be have something especial on the left side of the tray.
Lexmark X7675 error: Paper Jam (on printer control panel). Have turned off/unplugged several times, occasionally clears error, but it comes back. Sometimes just as paper has fed about 2 inches, sometimes...
Remove the cartridges. see any bits of paper left behind. Replace the cartridges. You will be asked to align again. Do this.
Hopefully, this will work
Good luck
luciana44
3helpful
2answers
Lexmark X5400 Series AIO Feed Problems
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks, Anu
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
5helpful
3answers
Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
