The most likely problem is that you've switched the focus from "auto" to "manual". If you're using the 18-55mm kit lens, check the barrel of the lens for a switch that is labelled with an "A" and an "M". Slide the switch towards the "A" and your photos should be in focus once more.
If you'd like to keep your lens in manual focus, twist the end of the barrel while looking through the view finder to focus.
