SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
SOURCE: How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
SOURCE: My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Testimonial: "Thank you very much. I found out I need special tool to remove the water pump's screws. It is not diffcult do it with diagrams. "
Is it the tub to pump or pump to drain section?
