VIA Rev 5 or later USB Universal Host Controller not work , give this messege
Windows has stopped this device because it has reported problems. (Code 43)
i use windows 7 ultimate sp 1
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition).
PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware:
* an AMD processor (350 MHz or higher)
* VIA Technologies USB Host Controller or SiS 7001 USB Host Controller
To find out what USB Host Controller is on your system:
1. Click Start > Settings and choose Control Panel.
2. Double click the System icon.
3. Choose the Device Manager tab. A window similar to the one shown below appears.
4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing.
5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
