Have you dropped it recently? If so, the ribbon connecting the screen might have come loose. If it does have a warranty, you will want to contact Canon and see if the issue is covered.
Otherwise, remove the battery, hold the power button to the on position for 10 seconds, then release. Place the battery back into the camera and turn on. This might clear any issues with power the screen might be experiencing.
SOURCE: black screen
Your Canon A75 camera has problem in CCD Imager and this part will be replaced to get back picture.
Canon announced free of cost repair scheme for subject problem and you can see details by clicking Canon CCD Advisory.
Hope this info will help you to resolve problem.
SOURCE: Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
SOURCE: Canon EOS 40D not working when turned on
Took to a camera store and they put my lens on a different camera body and lens didn't work. So the problem is the auto focus in the lens itself. It is nothing I can fix myself. I am now sending it to Canon for repair - hopefully won't need a new lens! Thanks for the help!
SOURCE: canon power shot SD750 can't take pic with flash
Hi
Your flash is defective, or the mainboard is defective and cannot control the flash. The only way to figure out which is the problem is to start by replacing the flash and see if it works.
You can probably find a parts camera online and use it to fix yours, if not let us know and we can help. We are an affordable digital camera repair business.
Thomas
Owner- Darntoothysam com
