Commonly the capacitor goes. Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
if the is a convection model then the covection coill will smell that way if there is a geese build up and should be ok to use. however you should only smell that if you are using the convection mode.
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
