Compaq cq60-466dx does not ship with a card slot or any media reader. You may use a compatible data cable for your phone to transfer media via USB. Also, you can easily get an external SD card reader which connects memory card to USB slot.
Good morning,
I believe I have found the answer to your question.
The service guide for the cq60 can be found at: http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Once you go there go to page 2-7 (page number can be found in the bottom left hand corner of each page). If you look under the "Left side components" the SD slot can be found at item marker #7.
I hope this helps.
Your laptop may not have a sd memeory card slot, if it has it should be either the front or either side, if none there, you can link your mobile phone to your laptop using a compatable usb. Should have had one provided when brought your phone.
