Question about Bose Acoustimass 10 II System
I BOUGHT A BOSE AM 10 AND ONKYO TX-SR508. IT IS WORKING FINE BUT NOT SURE ABOUT THE CONNECTIONS. ANY DRAWINGS OR DIRECTIONS FOR BEST REUSULTS FROM TV, DVD ETC TO ONKYO AND TO BOSE? HOW I CONNECT A FLASH DRIVE TO ONKYO, I DID NOT FIND ANY USP PORT.
    Brigadier General:
  • 8,546 Answers
The manuals that came with the units have the diagrams. You DO have them, right?
"Flash drive"? What type of interface does it have (USP)? This unit supports a dock for iPod. Page 50...
Posted on Mar 05, 2011
Anonymous
SOURCE:
Bose Cinemateonnect
Hi lechap,
With the indulgence of IB4G2008 as per his last post Feb 13.....
If I figure your concerns right, they are:
1. You have an iPod on an Onkyo IPod dock that you want to connect to an Onkyo receiver TX-302;
2. You have an Onkyo receiver TX-302 that you want to power a set of Bose Cinemate speakers;
3. the connectors on some do not fit or are not the same;
4. you want to know what goes to where.
If I may suggest:
a. connect the L/R Audio Out of the Onkyo IPod dock to the L/R Audio IN of VIDEO 1 using a pair of RCA to RCA cable. Connect the S Video Out of the Onkyo IPod dock to the Video IN of VIDEO 1 using an S Video to RCA Video cable. Thereafter if you want to watch a movie or play music from your iPod, you need to choose Video 1 in the Onkyo receiver TX-302. You can of course choose any other VIDEO 1~3;572fcdc.jpg34ab5d3.jpg
b. all other source/devices may be connected similarly using the same scheme on any of the free VIDEO / AUDIO inputs
c. of course the MONITOR OUT goes to your TV or projector.
With respect to the Bose Cinemate, it would not be technically correct to connect the Bose Cinemate speakers straight to the speaker out of the Onkyo receiver TX-302. You need to install another set of speakers to the speaker outs of the Onkyo receiver. The Bose Cinamate system's TV AUDIO could be connected to the TAPE OUT (or the AUDIO L/R OUT of VIDEO 1)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 13, 2008 | Onkyo TX-SR302 Receiver
No sound is coming out of the system
Hello, I may have a program where you can get this issue fixed at no charge. However, I can't be sure because of your location. Please email me the following information at askonkyo@us.onkyo.com:
Full Name
Address
Serial Number
Email Address
Phone Number
Thanks, FJD
May 15, 2016 | Onkyo Tx-nr808 7.2-channel Av Network...
Hi, I have brought an ONKYO TX-SR508 receiver and seem to be having problem getting a true picture. I am connecting it to my projector. When I connect the blue ray through the receiver, the picture keeps...
The reason you are not getting a good picture is because of the HDMI interlink cable. Make sure that the HDMI cables you have bought are at least version 1.3a. May be one of the cables is v1.3a that is why you are getting OK picture when you connect the projector directly ( it might be an expensive cable ) . If you do not get v1.3 you may also buy v1.4 which is 3D ready.
The poor band width of the cable must be giving you a bad picture.
Now if both your cables are OK and you are still getting a bad picture you have faulty HDMI pass through circuit on your TX-SR508.
Mar 28, 2011 | Onkyo TXSR508 Receiver
Hoe to connect Bose Lifestyle 25 Home Theater System speakers to onkyo SRX-508
Do you mean TX-SR508? The following should work even if that is not the exact model.
The LS25 supports ONLY analog stereo audio input and the speakers themselves are NOT desigend to be driven by anything BUT the LS25 electronics.
If you still want to use the LS25 as speakers just run an RCA cable pair from VCR / DVR Out on the Onkyo to the AUX IN on the LS25 Music Center.
http://www.retrevo.com/support/Onkyo-TX-SR508-Receivers-manual/id/23653ag910/t/2/
http://www.retrevo.com/support/Bose-Lifestyle-25-Series-I-Home-Theater-Systems-manual/id/525ag019/t/2/
Dec 28, 2010 | Bose Lifestyle 25 System
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Connecting a subwoofer
There are numerous systems that would be compatible with your system. Consult your dealer where you bought your RCVR..accordianman
Jan 14, 2008 | Onkyo TX-8511 Receiver
Bose Acoustimass 10 II System Logo
336 people viewed this question
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
