you need to look closely with a flashlight. there is a circuit that popped and you'll see one of the black circuits that is connected to the heat sink that looks different from the others.
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
You popped the plasma HV generator. Do you use a UPC all the time, if not then power line surges or brownouts can cause this type of problem. Needs Pro shop repair, expect around 450.00. PS: buy a upc for around 10 minutes run time $80.00 ??
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
