SOURCE: bad message
It sounds like a corruption or the messenger app is having communication issues. Did you try downloading a third app?
You could check for latest patches etc to make sure your o/s is up to date.
SOURCE: BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader
in the BlackBerry Desktop Manager to erase all data and applications
from the BlackBerry device. Refer to KB02318 for these steps. Once
Application Loader has completed, perform a syncronization or advanced
restore to restore the data to the BlackBerry device. To do this,
double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
SOURCE: I'm getting Uncaught Exception - Process
well one u messed up a piece of wiring in ur phone so take out the battery and then unscrew the back if the red wire has scratches or has been cut in a way there is ur problem if thats it u will need to take back the phone
SOURCE: Uncaught Exception: Application net_rim_bb_addressbook_app(268) is
That happens when the phone locks. Always remember to use the Menu button to close all programs instead of the back arrow or they will run in the background causing chaos (phone freezes).
When this happens...take the battery out with the phone on. Wait a few minute then put it back in for a reboot. If the problem doesn't clear up, you will need to either uninstall some programs or see a service center.
SOURCE: Blackberry 8520 uncaught exception: application net_rim_bb_messaging_app(456)
Restart the blackberry at first ! if this problem is still coming from Blackberry Messaging App, think about a fresh restore with the latest firmware using information from your carrier provider or blackberry website.
