Posted on Jul 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon ir C3100 Admin Password
I need to change the IP address of our Canon ir3100, but I don't know the admin password and it's not recorded anywhere. Is there any kind of hardware reset?
  • Anonymous Jul 30, 2008
    need to reset admin password
Anonymous
Level 2:
  • Canon Expert 287 Answers
  • Posted on Jul 31, 2008
Anonymous
Canon Expert
Level 2:
Answers
287
Questions
0
Helped
238255
Points
930
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15256
Points
How to resat administrator password
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Help me with my wep key please
Reset password of DGS3627 from console
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
1helpful
New password wifi
How 2 put the password?
I looked on line to get a password, but it won't accept it. I have an I pad that works everywhere else.
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
2helpful
Forgot my password and cannot reset?
All D-Link Dir configuration done but I can't access internet,why is that?
192.168.2.1
192.168.1.1
old marine
old marine
ZJ Limited
ZJ Limited
