SOURCE: swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
SOURCE: I am looking for replacement parts for a fisher
Mattel has some spare parts for this swing available for purchase here:
http://service.mattel.com/us/product_detail.asp?id=H0795&Ntt=H0795&Pn=1&Brand=Fisher-Price+Babygear&Cat=Swings
Look in the box on the right hand side of the page that says "Service Assistant". Inside there is a link to "Purchase Parts".
SOURCE: i have the fisher price deluxe take along swing.
I have the same swing and they confused me aswell as it says nothing about them on the instructions, but I had a look at the picture on the box and finally figured it out!
If you fold the swing completely flat (you can un clip the white parts on the base so the legs swing backwards so the swing is completley flat) then the two straps from underneath wrap around and secure it with the velcro! Hope that helps, Emily.
SOURCE: need a manual for a
hi it can be found here
http://service.mattel.com/instruction_sheets/J0418pr-0720.pdf
SOURCE: fisher price aquarium cradle swing mobile won't work
Possible problems causing this are corroded wires (batteries left in too long), and pinched or worn wires. To remove controls, use flathead screwdriver or butter knife, and lift out two bottom tabs - then lift and pull gently towards you to remove top tab.
Grey wires leading to mobile can easily get squished and sever, or worn through. I had to solder 2x grey wires that were severed. Lights are LED so very little chance of them all burning out.
