Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
i was wondering how do you unlock the TV SYSTEM function because i cant access it. Please let me know thanks.
If you are using the component plugs (three video plugs, one each, red, green, blue), make sure you have them matched up correctly. If one or more of the color cables are not paired up correctly, the video will default to black and while.
