Question about Salter Stainless Steel Electronic Bathroom Scale
Is deffinately working when you step on it comes up with 0.0 kg and then ERR help
    New Friend:
  • 15 Answers
EE means that the scale has been overloaded.is deffinately working when you - tek428.jpg
Posted on Mar 05, 2011
6ya staff
SOURCE:
Ounces to grams 1ounce to grams
How to convert Ounces to Grams How to convert Ounces (oz) to Grams (g).
Ounces to Grams ? Ounces to Grams conversion table Ounces (oz) Grams (g) Kilograms+Grams (kg+g) 0 oz 0 g 0 kg 0 g 0.1 oz 2.835 g 0 kg 2.835 g 1 oz 28.35 g 0 kg 28.35 g 2 oz 56.70 g 0 kg 56.70 g 3 oz 85.05 g 0 kg 85.05 g 4 oz 113.40 g 0 kg 113.40 g 5 oz 141.75 g 0 kg 141.75 g 6 oz 170.10 g 0 kg 170.10 g 7 oz 198.45 g 0 kg 198.45 g 8 oz 226.80 g 0 kg 226.80 g 9 oz 225.15 g 0 kg 225.15 g 10 oz 283.50 g 0 kg 283.50 g 20 oz 566.99 g 0 kg 566.99 g 30 oz 850.49 g 0 kg 850.49 g 40 oz 1133.98 g 1 kg 133.98 g 50 oz 1417.48 g 1 kg 417.48 g 60 oz 1700.97 g 1 kg 700.97 g 70 oz 1984.47 g 1 kg 984.47 g 80 oz 2267.96 g 2 kg 267.96 g 90 oz 2551.46 g 2 kg 551.46 g 100 oz 2834.95 g 2 kg 834.95 g 1000 oz 28349.52 g 28 kg 349.52 g
Jul 20, 2018 | Office Equipment & Supplies
Why head bolts torque are different from 2003 and 2005 1.8 nissan sentra?
I have never seen a code specifically identifying a blown head gasket. I checked the service manual and the procedure is the same.
4. Tighten cylinder head bolts (1) to (10) in numerical order as shown in 5 steps. Cylinder head bolts Step 1: 29.4 Nm (3.0 kg-m, 22 ft. lbs.) Step 2: 58,8 Nm (6.0 kg-m, 43 ft. lbs.) Step 3: 0 Nm (0 kg-m, 0 ft. lbs.) (loosen) Step 4: 27.4 - 31.4 Nm (2.8 - 3.2 kg-m, 21 - 23 ft. lbs.) Step 5: 50° - 55° (target: 50°) clockwise
images-xozrttqlr3qpoa0t2tmccx0o-1-0.png To confirm it is a head gasket, do a compression and/or leak down test. Wouldn't hurt to pressure test your cooling system as well.
Apr 16, 2017 | Nissan Cars & Trucks
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
When I first step on my scale, it registers "Lo". Then if I step off and back on, it will register 0 for a while and then come up with "Err".
It may be a low battery warning..
or
If it is like my scale, I apply pressure momentarily (1/2 second) to activate it, then once it has turned on and calibrated itself, I step on to get a measurement.
Aug 02, 2010 | Home
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
Salter Stainless Steel Electronic Bathroom Scale Logo
1,258 people viewed this question
Top Salter Health & Beauty Experts
Simon Ruddy
Simon Ruddy
Level 1 Expert
WordGoddess
Level 1 Expert
Terry
Terry
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
