The Panasonic web site is, for some reason, particularly devoid of support information for this printer. Unfortunately, you haven't indicated what exactly is occurring when you get this error number, and the site has taken several hours to locate relevant information. Unfortunately, to make a long story short, it appears that service is required, assuming that you have verified all of the obvious general troubleshooting steps (as indicated below).
If you have your manual, that is most often the best place to start to locate the meaning of a particular error. General troubleshooting would lead to suggest that you turn off and remove the power source for several minutes before restarting, see if the machine resets, and if not, follow up as below after checking all obvious error conditions (supplies, communications lines if any, paper jams, etc.) If you do not have your manual, there are a number of manuals relative to this model at:
http://service.us.panasonic.com/operman/findmanual.aspx?model=DP3520. However, the difficulty of locating information at the site would suggest to keep record of this location, as it has taken me nearly 2 hours to find it!
If you look at page 11 of
the Copy manual located at http://service.us.panasonic.com/OPERMANPDF/DP3520_COPY.PDF
you will see that it is indicated that, for any error code beginning with E, contact Service.
I have listed below all other such information as I could locate in regard to this printer. However, there is little to no available information regarding operation and/or errors in any of the generally expected and/or accessible areas.
The best bet may be to submit an online request for support directly from Panasonic. Complete the form at
http://www.panasonic.com/business/office/support-contact-us-form.asp and they should get back to you. All other references (other than below) refer us to dealers to get support for printers...
I was able to find a contact and number (Paul Wharton 201-392-6561). However, this was on a page re accessibility. Still, it is a Panasonic contact, and hopefully this person could direct you further. Other than that, please see below.
The main pages for this printer are at
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=66764&catGroupId=13843&surfModel=DP-3520&displayTab=O
AND
http://www.panasonic.com/office/templates/PDIC_HyperDoc.asp?Category=1029&ModelNo=DP-3520
The following is from
http://panasonic.co.jp/pcc/products/en/mfp/download/
WORKiO DP-3520, 4520, 6020
- GDI Printer Driver
Windows 98, Me, NT4.0, 2000, XP, Server 2003, Vista
- PDL Printer Driver
- GDI Printer Driver / PDL Printer Driver
Windows XP (x64), Server 2003 (x64)
- Adobe PostScript Printer Driver
- Panafax Desktop
- IPX-SPX setup wizard
Panafax Desktop Software Manual is at
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-c322/pdms/Manual/ENG/Panafax%20Desktop%20OI.pdf
Hope that some of this information is helpful. Please post back, if you need further assistance, with additional detail regarding exactly what is occurring with the machine (aside from the error code). However, based on the manual, it is likely not something that can be solved without service.
Thank you for using FixYa, and if you feel this information has provided excellent information regarding your problem, please rate this solution at a FixYa!
