Dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
I forgot my fone code my mob. Imei no is 352699048388113 plz send my fone code
Nokia x2 call log not delete
My phone x2-00 phone lock paz unlock solution sand my no 09926463746
Hello i forgot my security code my cell phone is nokia x2-00 and is imei is 35434604005019 please send code number
My nokia x2-00 imei is 358626048734933. can you please tell me my security code
My mobile Locked i lost my password plz give your solution.
I lost nokia security code how can i reset
Skype free call install
My nokia x2-00 imei is 356990040270607. can you please tell me my security code
Can you plis send me a code for my phone nokia x2-00 imei is 354346045795589
My nokia x2-00 imai is 358274048467814.can you pleas tell me my security code. my mobile number is 8769832923 please send my code.thanks
SOURCE: I lost my nokia x2 security code how can i reset
FOLLOW this link http://forum.gsmhosting.com/vbb/f550/how-remove-security-code-nokia-x2-step-step-guide-1139563/
SOURCE: my nokia x2-00 security code
Hi, the default security code for the Nokia Cellphone is 12345. If you have changed the security code of the Cellphone, then you need to flash the Cellphone which is done by any Mobile Service Center.
You may kindly note that the default security
code for all Nokia handsets is 12345. In the event the security code is changed
and you are unable to recall it, then the phone needs to be reset. You may
kindly note that the security code can be reset at any Nokia Care Center. Kindly be aware that there
will be a service provision fee associated with this service, as it is a
non-warranty procedure.
You may
kindly note, once the phone has been reset, all data in the mobile will be
lost. I recommend you take along the
proof of purchase/receipt while visiting the Nokia Care.
Good Luck.
Thanks for using FixYa.
You may
Good Luck.
