If the oven is dead - no display, no beeps when you press a pad on the keypad, and no inside light when you open the door - then I would suggest that you very the outlet is okay under load.
A hair dryer or toaster are the best ways the average DIYer can test the outlet under load.
If that's good, then your microwave may be dead due to a blown fuse, magnetron thermostat, or oven cavity thermostat.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If the fuse and magnetron thermostat are good, then you will have to take the oven down from the wall to get to and test the oven thermostat.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here. We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
When you press start d you hear a click? If not the relay on the control board for the High Voltage section is not working. If yes then I would check the MAG, the Cap/Diode or the Transformer. Eric
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
