Question about One For All URC-9800 LCD Remote Control
The settings button on my urc remote will not activate to go to the settings. i am trying to turn on closed caption. thank you in advance for your help.
  • 2,509 Answers
Try another code, sometimes there are several similar ones. Check with One for All.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Posted on Mar 04, 2011
6ya staff
SOURCE:
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How do I turn off closed caption
Sometimes it isn't the remote, it is the cable or satellite set up menu. Try Menu/Setup/Closed Captions and see what happens.
Feb 21, 2015 | Logitech Harmony 670 Advanced Universal...
How do i turn on the caption with universal remote RCr311W to a sanyo tv moel#DS27820 ?
Here is the link to the User's Manual for that universal remote control:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RCR311W_DOC_OM.pdf
Unfortunately there is no dedicated button on that particular universal remote for operating the Closed Captioning feature on your TV.
You can try using the MENU button on that remote in order to access the AUDIO OPTIONS on your TV. Then see if you can activate the CLOSED CAPTIONING from there. See page 5 of the above manual for instructions on how to operate the MENU button on that remote.
Otherwise you will have to use the original factory remote control that came with the TV, or go out and buy a more expensive / advanced universal remote control with all the additional features and buttons that you require.
Good luck.
Joe.
Dec 09, 2011 | Sanyo Televison & Video
A black screen appeared on my TV. I know it has something to do with programing it using the remote control for the Insignia converter box, but I can not figure it out. can somebody help please? Thanks...
First look for the cc button (closed captioning) on the remote control. Press it several times back to back to scroll through the various options. Finally press the button until you see that it has cycled to "off." If this doesn't work then
Press menu and locate where the closed captioning settings are. You will see that you have the closed captioning set up for text. When you go into the closed captioning menu category and select off the black box will go away.
Feb 17, 2011 | Zenith Televison & Video
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Missing Close Captioning (Unable to Activate)
get you cable company to give you the code to undo their control of your tv with their remote then try the cc button on the Protron remote and check the miscellaneous section 3 of your controls and make sure the closed caption option is not on
Apr 30, 2007 | Protron PLTV-32 Television
One For All URC-9800 LCD Remote Control Logo
Top One For All Televison & Video Experts
Joe Negus
Joe Negus
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
