The KX-TGA711 handset can be added to the KX-TGA7160 or KX-TGA7180 system. First, make sure that the answer system is ON. (Use the button on the base or the first few steps below.) For those base units, press the Menu/OK button on the handset. Use the Up/Down arrows to navigate to Answer System. Press the right arrow to enter the sub-menu. If the system is off, turn it on. (Answer On/Answer Off will be displayed on one line. Press the right arrow to access the item.) To record a new greeting, navigate to the line 'Record Greeting' and press the right arrow. Hold the handset about 20 cm away and speak clearly into the microphone. Press Menu/OK to stop recording. Press the Hangup/End to exit and save. A faster access route would be to press 7 and then 6 after accessing the answer system menu. The directions are on page 25 of the manual, which is available from Panasonic and here: http://www.home-phones.co.uk/assets/uploaded/documents/473_7160.pdf . You can do this as a remote operation if you have enabled the feature. Press 7 to record and 9 to stop recording.
Making an intercom call
1 Press {INTERCOM}
2 Select the handset you want to page
by pressing the desired handset
number ({1} – {6}).
To stop paging, press {OFF}.
3 When you finish talking, press
{OFF}.
Answering an intercom call
1 Press {handset icon} or {speaker icon} to answer the
page.
2 When you finish talking, press
{OFF}.
Note:
When the ringer volume is set to off,
the handset rings at the low level for
the intercom calls.
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
