AT&T 1818 Corded Phone Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't turn the ringer on. the light says "ringer
Anonymous
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
114
Questions
Helped
12454
Points
353
Turn the volume all the way up. maybe this will help u
3helpful
How do I turn the ringer back on on the Uniden dect 6.0
The procedure varies from phone to phone. Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
1helpful
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
How do I reset ringer to "on" if it is set on "off"
Hello
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Method Two
Press the down arrow key until you reach "Ringer Vol," then press "Select."
Press the up arrow key until to increase the ringer volume you want then press "Select."
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
How do I go from "ringer off" to "ringer on"??
Assuming that this is a digital phone with a Navigator button (like 76xx or DTxxx), then press either the RING OFF soft key and the up button on the navigator button, or just keep pressing the up button on the navigator and the RING OFF will change to a level and the phone will ring.
Carl
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Flashing Light and Ringer
flashing light means ur phone is turned on and working properly and go to ur profile menu then click for personalised then change for ringer type
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
