it would be depending on the cable that you used to connect the roku to tv. if you're using hdmi cable, make sure to set the input source of the tv to hdmi. if you're using a/v cable, set the input source of the tv to video.
Make sure your DVD player has HDMI or Component RGB output,you will also need RGB component cables or HDMI cables to connect the DVD player to your Vizio,once you have attached one of the above cables you will need to press the input button on your TV'S remote to select either HDMI or Component.
was the VHS recording before the new high definition TV was installed? Or are you trying to say that the cable company has tempered with the settings of the VHS?
Probably, the cable company, has removed the cable for the player. Check the back of the player and let me know if the cable between the player and the TV are intact.
The above needs to be verified for accurate solution.
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
What colour wires does the new dvd player have? The colours correspond with the socket that you plug them into. If your new dvd player only has yellow red and white cables then that is all you need. if they are red blue and green then you will also need to plug the appropriate audio cable into the dvd player. If you need more help please tell me the model of dvd player and the model of tv
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
you need to go buy what they call a dvd modulator so you can connect using coax cable to the tv as long as the tv is cable ready they cost about $30.00 walmart , bestbuy etc
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable. Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
