I actually did change my low beam bulb with ease. I took pictures to help with step by step procedures.
Step 1.
Step 2.
Step 3.
Remove the red dotted plastic plugs out. So you have wiggle room.
Once
removed all the red dots, where the green dots are you can gently lift
it past it, and pull it towards the front away from the engine.
Step 4.
Find the white latch and pull it up to the little square:
This you will see if you have pulled to far up, it has to match up with the little white square.
Step 5.
Black Latch, pull it up just the same way for the white latch, but you will need to unscrew the lock screw.
Step 6.
The light bulb port has to be turned clockwise to unscrew, opposite to lock back it in again.
Step 7.
Once
done it should like this, and you will need to a flat screw driver to
pop the little clips on the side of the holder and replace bulb.
Step 8, put everything back together and you are done.
