Plug the drive into your computer. Go to "My Comptuer", and right click on the drive's image, and select "Format". In the options for formatting set the file system to "Fat32".
Please remember to backup anything on this drive, as formatting will delete it all.
Welcome to Fixya. if your want to format the HardDrive to Fat32 File system you need to use a Windows XP or Windows 7 computer. Windows Vista dont have Fat32 but Exfat File format.
Go to Computer or My Computer then Right Click on the Beyond Micro Drive then select Format. Select Fat32 as file type.
Thanks for using Fixya
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Assuming you're using Windows OS, after you plug the drive in to your computer, right click on the drive. Then select "Format" Under "File System", select FAT32.
In computer right click the hard drive, select format. On the dialog that opens, set the filesystem to FAT32, then format the drive. You're done. Be careful, doing this will delete everything on the hard disk.
SOURCE: Format from NTFS to FAT 32
You'll want to leave this drive in NTFS format as FAT32 has lots of limitations in cluster size and total drive size.
The issue with your DVD- Media Player has nothing to do with how you formatted an external 1TB HDD.
It's possible that the two occured at the same time for different reasons.
SOURCE: How can I format my Seagate FreeAgent 250 GB USB
that's easy: 1.
my computer-right click format then when if formated -right click again then format and select FAT32
2. to have one partition download a program (partition magic or acronis in the trial mode and resize the partitions to be just one).
SOURCE: formatting hard drive to fat32
Xbox was not created to use external hard drives otherwise the software for it would be even bigger considering it is a gaming console. It might work if you use FAT but I can't say it for sure.
SOURCE: How can i format 1TB Toshiba Canvio portable hard
Right Click on your new drive in the Computer
Choose
a File System (NTFS is ideal most cases) and give the new volume a name
if you choose. You might like to call it something like "Portable
Drive," or "Removeable Drive." If not, just take the defaults and click
"OK."
You
will get one last warning that you are about to format your drive and
erase all data. Click OK to proceed. When you see the process has
reached 100%, you are done and you're new external hard drive is ready
to use!
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
