Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Protron pltv-26 model name lt26c1p1
Tv went black was still getting sound now the red power lite turns on to green then red then it went to a dimmer red but tv will not go on
  • 2 more comments
  • campie44 Sep 08, 2008
    same thing happenineg to me cant access menu to change to factory default.
  • whitetailgal Sep 13, 2008
    I can hear sound but screen is black...everytime I flip thru channels..I can see picture clearly for a second..but then back to black screen?
  • Noahzipp Sep 16, 2008
    tv flashes white for 1 second then goes black. PLEASE HELP!
  • Anonymous Nov 05, 2008
    model# lt26c1p1
    Sergeant:
  • 359 Answers
1-877-778-8876
Call for a service call
Posted on Aug 18, 2008
6ya staff
SOURCE:
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Tv go's off then on, green lite stays on. placed
Sounds like the lamp is getting weak, change it.
Oct 28, 2009 | Televison & Video
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
My television screen went black, but there is has sound
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Aug 15, 2009 | Televison & Video
House has two black and one white. dimmer has one black, one green and one red. WHat connects to what? THanks
Black wires are the hot side the power line, white is the neutral, and green is ground. On your dimmer, the black wire is for the AC input and the red wire is the output to the lamp you want to control.
If you are replacing an old switch with the dimmer, the two black wires will be connected to the screw terminals on the switch. One of those black wires is the AC feed to the switch, the other black is the one that goes to the light fixture. You'll need to determine which is which so you can hook the dimmer up correctly.
For a few dollars you can pick up a tester that lights and chirps when it's near a hot wire. Turn off power to the light circuit at your circuit breaker or fuse panel. Remove the old switch and disconnect the wires. Make sure the bare ends are not touching anything and turn the power back on. Hold the tester near each of the black wires. One of them will cause the tester to light up and the other one will not. The unpowered wire is the one going to the light fixture. This one connects to the red wire on the new dimmer. The hot wire is the feed that connects to the dimmer black wire. The green wire on the dimmer connects to the other green wires already in the box. Turn the power off again and make your connections using UL approved twist-on connectors (wire nuts), which probably came with the dimmer. Fit the wires and dimmer back into the switch box, secure it with the mounting screws, replace the cover plate and turn the power back on.
Voila! You'll have a working dimmer. A Google search for "installing dimmers" will turn up several links to sites with good pictures.
Apr 11, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Red lite blinking
help mine is doing it also, 4 blinks, no power
if any gets it fixed or knows how please email me at
ron1978@comcast.net thanks
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
394 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
