That code is for a MIL indicator malfunction-in other words, your check engine light is malfunctioning...do you have a MIL light that works when you turn you key on, before starting? If not, the bulb is blown out, and you should replace it. If it does work, I'd suggest disconnecting the negative battery cable and letting the car sit for 5 minutes, then start it up and let it idle (no gas at all) for 5 minutes, then drive it lightly for another 5-if the light stays on, you have a malfunction with either the wiring to the light or possibly the ECM.
