Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
