My understanding is all upgrades are available by using the Nokia 'Phone Software Update' available on their support site. If you simply want to upgrade, I recommend using that.
Link to Nokia's support for the 6300 is HERE
Hope that helps.
I suggest
1. download nokia software update at
http://europe.nokia.com/support/download-software/device-software-update/download
2. folowing this instruction at
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
or
try download nokia 6300 firmware at
http://rapidshare.com/files/243098465/RM-217_DP20_9.00__sw-07.30_6300.exe
using flasher upgrade your handphone firmware.
SOURCE: how can i upgrade software of my nokia 6300
Visit http://mea.nokia.com/get-support-and-software-en/download-software
Rate my solution
SOURCE: Nokia 6300
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone.
Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
SOURCE: nokia 6300 software
Here is a link to the Nokia PC Software Suite. http://www.nokiausa.com/get-support-and-software/product-support/nokia-6300/pc-software
As long as you have the USB cord from the phone to the computer after you download that it should guide you through the steps to transfer whatever data you want moved
