Instead of aux (Blue Connector of PC Sound), try using head phone jack (Green Connector of PC Sound). It if is working fine, uninstall sound driver of your PC, restart PC and install sound driver again. Your problem will be fixed.
If the modem works and a desktop pc works through the Ethernet port of the router, then try plugging the pc laptop into the same Ethernet port using the same cable as the desktop. Most laptops have an Ethernet port.
If this works, then the problem is the wireless access?
Check you still have the wireless set-up on the pc laptop, if not re-install it.
try the device in another pc. if it works, then try it back in the pc with the issue. windows normally recognizes usb's if you cant get it to work, try it in a second slot on your pc. if it still doesnt work, your pc usb slot probably does not work
try the bios settings is your monitor in a grafics card slot also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Maybe the batteries are dead, or it needs to be reconfigured to work. sometimes there are buttons on each device to help them connect to each other. Try it out.
Try other monitor(which is working fine) to your pc,if it work...it means your monitor gone bad.
If it doesn't work.. try to connect your neovo f-419 to the other pc to check if it is working.....,if it does,your pc's videochip/videocard or badmotherboard may cause the problem
You know it works on the PC but nothing is working? Sorry, this isn't very clear, is the controller not working on the 360 or the PC? More explanation is needed here I think
Do other peripherals work on the same USB port.
