Computers & Internet Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant sand my data to pen drive frm my pc - Computers & Internet
Tech support
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Mar 03, 2011
Tech support
Expert
Level 2:
Novelist:
Answers
136
Questions
0
Helped
31718
Points
415
If you are not able to send data to your pen drive from your PC that means your pen drive does not have space to carry more data. Please check the space in your pen drive that how much space left in your pen drive or do you have any space left in your pen drive.
to check space in your pen drive follow this:-
open computer or my computer>right click on pen drive icon>left click on properties>now you check the used space and unused pace.
If there is a space left in your pen drive then how much space left because you can download or transferred your data to pen drive up to that limit that space you have left in your pen drive.
If you have no space left in your pen drive or very less space then you can increase the space by moving some files from your pen drive and saving it up in another place in your computer
tip
How to recover data from Pen Drive
Pen Drive gives ussignificant convenience in today's business life. However, due to human errorsor other reasons, we often meet embarrassed phenomena of losing Pen Drive data. The following are sometypically cases in our daily business life.b>
Practical cases:
1. Pen drive still contain all data, and the space shows the same likebefore, but all files and folders in the pen drive are changed to shortcut.
Cause:
Your pen drive was attackedby virus
Resolution one:
If you oftenuse Pen Drive to transfer data from one computer to another, make sure thecomputer is well protected. If any computer is not protected against virusattacks, the files and folders in Pen Drive may be gone or just change intoshortcut. If that happens, don't panic, you can still get back lost data, Firstly, remove the virus, connect your Pen Drive to one PC that is protectedwith a good antivirus and then scan it, fix all the virus threats that aredetected by the antivirus, After completing scanning, some of the useful filesor folders may deleted. Secondly, use pen drive data recovery program torecover deleted infected files.
Resolution two:
If you can'tdelete virus in Pen Drive, just format Pen Drive and then use data recoveryprogram to retrieve data.b>
2. When transfer files from Pen Drive to PC, mistakenly removed the PenDrive from USB port and some data lost, or press "format" command during theprocess of using Pen Drive. Sometimes, delete data in Pen Drive in one day andfind it is useful in another day and want to recover them.
Cause:
Human error
Resolution:
The data youonce have saved in your pen drive is real hard to remove completely. Firstthing to do is stop using the Pen Drive as the chances of your data beingoverwritten increase as time goes on. Then choose a perfect data recoveryprogram. There are many Pen Drive data recoveryprogram in the internet. Although Ihaven't tested them one by one, Card Data Recovery is the most popular one inthese days.
Steps to recover data fromPen Drive using Card Data Recovery
1.
Plug the Pen Drive into yourcomputer using USB port;
2.
Download Card Data Recoveryand install it on your computer;
3.
Check whether your Pen Drivedisk display in your computer;
4.
Select your Pen Drive;5. Run Card Data Recovery andcontinue the operation under the interface instruction.b>
on Jul 20, 2011 • Computers & Internet
tip
How to make ur pen drive long lasting
1. try to always keep ur pen drive mouth cover with the cab when nt in use, in order to prevent the steel surface to get rust.
2. always try to delete the files inside the pen drive than formatting, in order to nt decrease the volume the size of the pen drive.
3. dnt use pen drive when it is vry hot, in order to prevent it frm getting damaged.
For more tips, vote me
on Mar 24, 2010 • Computers & Internet
4helpful
2answers
Cant Format pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
1helpful
2answers
Cant
in jeneral memory card meance card reader ( mobile/d igitalcamer/phone cards where we put photo song.....etc) it is as pen drive device we put data directly in pen drive but in card reader . we put data in memory card through cardreader. both are use in computer usb port. computer dected card reader as apen drive.
are you not saying about ram ? it is also called memory. it is use in mother bord slot. they are white and plastic.
1helpful
2answers
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
Cant store data
try re-partition and re-format your pen-drive
1helpful
Transcend pen drive 16gb+write protected
Dear,
No, problem
Just copy the whole data of pen drive to PC. Now format the pen drive
and paste the data from PC to pen drive again. It will work fine then
Thanks,
Regards,
Rakesh Kumar
Faulty usb pen drive
If you have one working computer try it there. If you cant still open your usb pen drive the usb is defective
Grand Canyon Tech
Grand Canyon Tech
