Apple iPhone 3G Logo
Posted on Mar 03, 2011
How to delet an individual dialed or received number on iphone4
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2373
Points
13
Apple does not allow you to delete individual dialed or received numbers in your call history.
It is possible however, if you jailbreak your iPhone. For instructions on how to do this, visit this link
HOW DO I DELETE VOICE MESSAGES WITHOUT LISTENING TO THEM ON IPHONE 4G
I don't believe voice messages are held on your iPhone itself.
Voice Messages are held by the Carrier you are connected with. Usually you dial the voice message service and delete the recorded messages at their end.
I asked my carrier to turn off the Voice Message service because it became a pain to deal with. That way I can see on my iPhone who has called and call them back if I want.
The iPhone is either a 4 or 4S. There is no 4G
4G is currently the fastest network speed that the phone carrier puts out. The previous one was the 3G network.
Cheers
How to remove call from call logs?
Your cell phone keeps track of every call you make and receive through it, including a caller's phone number and the date and time a call took place. If you answered the call, it records how long you talked. If you do not want this type of information about your habits to remain on your phone, you can delete records of individual cell phone calls received, dialed or missed, or delete the entire call log at once.
Delete Call Log
1.From the home screen, click the "Menu" button on your phone to navigate to the main menu of your cell phone. This is where your call log application is located, among other features such as your address book and text messaging.
2.Click on the "Call Log" or "Recent Calls" icon. The name may vary slightly depending on your cell phone provider.
3.Select " All Calls" from the call log screen.
4.Scroll down and select "Delete All." This will delete all calls from your call log.
2answers
Using my Nokia C6 phone , How i can delete a single entry from my call leg rather than delete the whole entries. for example how delete a single number from the recieved or dialed numbers?
Its easy. Just go to that call log. For instance, you want to delete XYZ's number from the received calls log, go to you recieved calls, scroll to XYZ, select 'options'. In the options, select 'delete'. You would be asked if you actually want to delete the number XYZ from the received calls log. Selecting 'yes' deletes the number.
You can do the same for your dialled and missed calls.
Hope that helped you?
Have a wonderful day.
When dialing number it is giving a "wrong number" signal
As you said, the set up is either trying to dial a "9" or other number to access an outside line before dialing your destination number. You will need to get into the menu and delete that command. After that, you should be able to dial out.
Remember to have the fax set to "FAX" not "TELEPHONE" to send and receive automatically.
I WANT TO SEND THE SAME FAX TO SEVERAL NUMBERS
You are wanting to use the Broadcast feature of your fax machine. According to page 65 of the users manual, you load the documents, press Broadcast, and enter the receiving numbers by using the rapid keys, speed dial keys, group keys, or individual telephone numbers (maximum of 20) pressing Start/Enter between each of the entries (except for the rapid keys and speed dial keys). Set your contrast and resolution (if desired) then press Start/Enter twice to being.
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
1helpful
2answers
How to send a fax to multiple recipients
After each number you dial, press "SET" then dial the next number
After you put in your last number hit "SEND"
You will receive a confirmation with a compilation of all the numbers you sent to after all numbers receive their faxes.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
