Fitting the scanner wires
NOTE:
When fitting the wires, be sure to use those specified below.
Machine front: (P/N: 2C91236), gray
Machine rear: (P/N: 2C91235), black
Fitting requires the following tools
Two frame securing tools (P/N 302C968310)
Two scanner wire stoppers (P/N 3596811)
Procedure
1. Remove the rear cover.
2. Remove the screw and remove the scanner wire drum gear from the rear side of themachine.
3. Remove the stop ring and bush.
4. Remove the stop ring and bush from the front of the machine.
5. Remove the scanner wire drum shaft from the scanner unit.
6. Insert the locating ball on each of the scanner wires into the hole in the respective
scanner wire drum and wind the scanner wire three turns inward and four turns outward.
With the locating ball as the reference point, wind the shorter end of each of the wires outward.
7. Secure the scanner wires using the scanner wire stoppers.
8. Refit the scanner wire drum shaft to the scanner unit.
9. Insert the two frame securing tools into the positioning holes at the front
and rear of the scanner unit to fix the mirror 2 frame in position.
10. Loop the outer ends of the scanner wires around the outer grooves in the pulleys on the mirror 2 frame, winding from below to above.
11. Hook the round terminals onto the catches inside the scanner unit.
12. Loop the inner ends of the scanner wires around the grooves in the pulleys at the left of the scanner unit, winding from below to above.
13. Loop the scanner wires around the inner grooves in the pulleys on the mirror 2 frame, winding from above to below.
14.Wind the scanner wires around the grooves in the scanner wire guides at the left of the scanner unit.
15. Hook the round terminals onto the scanner wire springs.
16. Remove two scanner wire stoppers and frame securing tools.
17. Focusing on the locating ball of the wire drum, move aside the wires to inside.
18.Move the mirror 2 frame from side to side to correctly locate the wires in position.
19. Put the mirror 1 frame on the scanner rail and move it toward the left side of the machine.
20. Insert the frame securing tools into the positioning holes (leftmost holes) at the front and
rear of the scanner unit and screw the mirror 1 frame while securing both the mirror 1 frame and the mirror 2 frame.
21. Remove two frame securing tools.
22. Refit all the removed parts.
I hope this is helpful,
Shawn
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
Do you have the scanner option installed on your copier? There is a scan button on the left side of your operation panel but that doesn't mean you have a scanner. The scanner NIC if installed would be located on the left side of the machine several inches above the printer network connection.
