Yahoo Mail Logo
A
Anonymous Posted on Mar 03, 2011
This is my new yahoo mail id wht not opened with right password and name
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Answers
64
Questions
0
Helped
16326
Points
259
You much check your profile or go to this link to solve your problem... just follow procedure..
https://edit.yahoo.com/forgotroot?done=http%3A%2F%2Fmessenger.yahoo.com%2F&src=pg&partner=reg&intl=us
I have forgotten my yahoo password and my secret answer i want to open my mail inbox as soon as possible please
you may send your account name and password...
change the password afterwards.... if it's okay with you...
tip
How to have two e-mail addresses in same yahoo ID.
So many users still not aware of this tricks, how to get two e-mail address on same ID. The process is given below.
Step 1: Login your ID in http://www.yahoo.com/r/m6 or http://mail.yahoo.com
Click on Options [Right side top]
click on More Options from the list [ Image as below]
On next screen click on Accounts [as below] and click on Add or edit an account,
If you want to add an extra yahoo email address click on Get started [#3], On next screen see right side for possible ID, select one of those and click choose or type manually in the box on left side and click check availability, If the ID is available, it will proceed you to create the email address. You may need to verify the Password if you confirmed the ID. and then you can start using the new email address on same yahoo ID.
Again if you want to receive or send email using non-yahoo email account from same yahoo address [#2]....just click on Add, on next screen as below
Put user name /email as e.g. [email protected]
put mail server correctly...and password as well.
then click next/continue and on next screen click on Send Verification to verify your non-yahoo account.
Open your non yahoo account and verify the email address.
Once verification is finished..you are done.....Now you can check/send/receive mails in your yahoo account from non-yahoo account.
Please remember that if you add an extra yahoo mail address that can be changed 2 times in a year only...so please careful about choosing your new ID.
Thanks for being with Fixya.
For more Trips and help please stay connected. Good Luck to all..
on Mar 18, 2010 • Computers & Internet
I cant open my yahoo account y..? my password and id also correct
Upen yahoo mail from http://mail.yahoo.com
Input your ID fully, i.e. ******@yahoo.com, not only ID name
Input Password, remember CAPS LOCK case sensitive.
Click Sign In.
Hope this help
Feb 03, 2011 • Yahoo Mail
I can't sing in to my ym
Dear Friend,
  • Check your Yahoo ID is CORRECT(Use ID using for Opening Yahoo mail)
  • Check Password(Use Password using for Opening Yahoo mail)
  • OFF caps Lock if it is ON
  • Try to Sign in With DIFFERENT MAIL ID
Still Problem
  1. Uninstall Yahoo messenger From Computer
  2. Reboot PC
  3. Click here and Install latest Version
  4. TYPE user Name & password Correctly
  5. You are solved
Still problem Reply here as Which ID is your Yahoo ID..You will be Solved....
If This Helped you Do Rate Me.. Thanks For Using FixYa.....
My email address is not recognize in yahoo messenger
Dear Brother,
Still Problem
  2. Reboot PC
  5. You are solved
2answers
How to unlock a yahoo mail id
try to login not by yahoo messenger, but by mail of yahoo which has a same user name and password that been locked. Sometime, this step worked, but make sure after your login to yahoo mail and success, you have to change your password with new password, and then you can login to yahoo messenger with new password that you just been created.
2helpful
2answers
I cant open my mail acount I have right ID and password!!!!
Yeah they really are concerned. They havent even bothered looking into the problem. Yahoo doesnt care. They are more concerened about wiping out searches on Obamas non existent birth certificate.
Jul 28, 2009 • Yahoo Mail
10helpful
4answers
I can singin in Yahoo Messanger
You can or can't signing in please write clearly.....
I'm trying to set up outlook and it won't accept my yahoo email password
  • Open Outlook Express.
  • From the tool bar, Click Tools > Accounts.
  • The Internet Accounts pop-up window will appear, with the Mail tab in the foreground.
  • Click Add, select Mail.
  • The Internet Connection Wizard pop-up window is now displayed.
  • Key in your name and click Next.
  • Enter the full Yahoo address.
  • Click Next. (For example, you should enter "[email protected]")
  • For E-mail Server Names, select POP3 as your option from the drop down. Type "localhost" for both Incoming (POP3) and Outgoing mail (SMTP) servers.
  • Click Next.
  • For Internet Mail Logon window, type your Yahoo! Mail ID and password:
    • Type just the the yahoo ID (for example, if your yahoo mail ID is [email protected], you need to type Username1 as your user ID)
    • Password is your Yahoo! Mail password. (Ensure you are entering the correct password)
  • If you do not wish to type in your password every time you check your mail, tick the Remember password box.
  • Click Next.
  • Click Finish.
  • Now in the Internet Accounts window, click on the new account named localhost and click Properties.
  • Localhost properties windows will pop up.
  • Select Servers tab and in the bottom tick the checkbox My server requires authentication.
  • Click Settings.
  • In the Outgoing Mail Server window, check the Log on using button and enter your Yahoo! Mail address as the Account name and your Yahoo! Mail password as the password.
  • Click OK.
  • Next select the Advanced tab and increase the Server Timeout to Long (5 minutes).
  • Click OK and close.
  • Now your configuration settings are ended and you should be able to access your free Yahoo! Mail account in Outlook Express.
1helpful
4answers
Please retrieve my stolen password
New security strategies at http://exquipass.blogspot.com
Protect yourself against email hacks, id theft and password theft at http://exquipass.blogspot.com
NO MORE STOLEN or LOST passwords!
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
