Clarke Power Products Clarke 130EN Mig 110 Volt Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a clarke 125en wire feed drive wheels are not turn although it makes the same noise as it did when it worked, it just up and quit
Anonymous
Level 2:
  • Expert 92 Answers
  • Posted on Nov 29, 2011
Anonymous
Expert
Level 2:
Answers
92
Questions
Helped
72573
Points
145
Release the tension from the WFR, pull the trigger and check the shaft that the rollers are attached is spinning if yes then the woodruff key is either missing or broken if no then the drive motor needs looking at, the shaft may have broken further along. get an electrician to check it out.
It willnot weld
if it is just not feeding wire, check the tension on feed wheel. Make sure it turns when trigger is pressed. Also make sure you have gas with solid wire. If you have cored wire gas is not needed.
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
I have a Clarke weld 130 en turbo and would like to buy nother wire drive wheel for the it as the wheels goes around but does not drive the wire through .could you help tthanks.
I do not know of a US source for these Clarke EN130 Wire drive wheel parts. I don't know of any interchangeable subs either. Your welder was made in Italy and the wheel drive is metric.
This is probably your best bet in trying to find any parts for it:
http://www.clarkeinternational.com/shop/search/filter/EN130/page/1
Not sure if you knew this:
Clarke Power Products Files in Toledo
Clarke Power Products Inc., a wholesale distributor of power equipment from Perrysburg, Ohio, filed a Chapter 11 petition on Jan. 8, 2009 in Toledo, saying it owes $7.9 million to the secured creditor Key Bank.
Court papers say assets of $13.8 million are comprised of accounts receivable, inventory and cash. Clarke’s products include air compressors and power tools.
The case is In re Clarke Power Products Inc., 09-30071, U.S. Bankruptcy Court, Northern District of Ohio (Toledo).
Thanks for choosing FixYa.
Kelly
Clark 130en does not feed well. Feeds great on 10
try checking the tension on the feed roller,you may have too much tension which in return will not allow the wire to feed right,check to make sure your feed roller is for the size of wire you are using,next check the tip size for the wire your using.
Welder always pulsates and doesnt feed wire at a steady speed. There is also a humm sound when you turn it on also sometimes it doesnt work at all
Most welders hum when turned on. The pulsation could be the unsteady feed. The feed could be one of several things. The rollers that drive the wire could be adjusted too loose. The tip could be damaged/burnt/melted. The tube that the wire feeds through inside the lead could be damaged or kinked. Be careful when welding that you don't have the lead bent too much -- keep it as straight as possible. This will minimize problems due to kinking. When you say it doesn't work at all, if you mean doesn't feed, this could be the same problem. If it doesn't turn on at all, that's something else. Post more details and we'll see what we can do.
Looking for a wire feed roller for Clarke Welder
Google Clarke welder parts to find a supplier. Or alot of auto parts stores sell that brand should be able to get it for you. I have a JET drill press that I needed parts for and found that my local NAPA store could get them and they don't even stock any Jet equipment.
1helpful
Where do i find tips for a clarke 100 mig welder
i own a 125en clarke, i bought tips from harbor freight....chicago electric, they fit, also they have tweco style guns, lincoln is interchangeable with them
3helpful
2answers
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Top Clarke Power Products Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
