I am trying to get a user manual for my motorola i1 phone so that i can figure out how to setup my voicemail on my phone. Without the manual and instructions I cannot do that. I am having a hard time trying to setup my voicemail, I have no instructions on how to setup my voicemail.
You asked for the manual, I gave you the link to the manual. How is that a 1?You asked for the manual, I gave you the link to the manual. How is that a 1?
You can't post conmments that contain an email address.
The fast busy signal that you are hearing after a voicemail is left on your Motorola CD4 cordless phone is most likely due to a problem with your voicemail service or your phone line. Here are a few things that you can try to resolve the issue:
Contact your phone service provider: If the fast busy signal is being caused by a problem with your phone line or voicemail service, your phone service provider should be able to help you resolve the issue.
Reset your phone: Try resetting your Motorola CD4 cordless phone to its default settings. You can do this by unplugging the phone's base unit and removing the batteries from the handset. Wait for a few minutes and then reconnect the base unit and reinstall the batteries.
Check your voicemail settings: Make sure that your voicemail settings are configured correctly. Check your phone's user manual to see how to access and adjust your voicemail settings.
Try a different phone: If the problem persists, try using a different phone on the same phone line. If the different phone works properly, the issue is most likely with your Motorola CD4 cordless phone.
You may contact to your service provider Motorola i1 Unlock Code, they will supply you a code fast. You may visit Motorola Unlock Code site, they will provide an accurate code with easy to follow instructions on how to unlock your phone. Once your phone is unlock, it will work with any network worldwide without sticking to one network only.
Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
