Bosch classic xx tumbler dryer keeps switching off saying filter blocked. when check all is ok, open door check and shut door and press on button and will work again for about 10 min.. the ducting path has been vaccumed but problem persists.. how can i recitify or by pass /overide this feature.
The issue you are experiencing with your Bosch Maxx7 sensitive dryer could indeed be related to a faulty heat sensor or a clogged vent. Here are a few troubleshooting steps you can try:
Check the vent: Ensure that the dryer vent hose is not clogged or blocked. A blocked vent can prevent hot air from circulating in the dryer and trigger the overheat sensor to shut down the machine.
Clean the lint filter: Remove the lint filter and clean it thoroughly. A clogged lint filter can also cause the dryer to overheat and shut down.
Check the heating element: If the heating element is faulty, the dryer may not heat properly or may overheat and trigger the sensor to shut down the machine.
Reset the machine: Turn off the power to the dryer for a few minutes and then turn it back on. This may reset the machine and resolve the issue.
If none of these troubleshooting steps resolve the issue, it may be best to contact a qualified technician to inspect and repair the machine.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is onONposition. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt.The belt safety switch is attached to theTensionerand motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under theTensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly checkurDOOR SWITCH ?for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Electric dryer no start does nothing
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet. 2
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel. 4
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut. Lint Filter 5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door. 6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction. 7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool. Clothing Not Fully Dry 8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month. 9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door. 10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content. 11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Mine did this. Because the bottom left filter was blocked the overheat
cut out had tripped. This is inside the rear of the machine accessible
after removing the rear panel
