Canon PIXMA MP830 All-In-One InkJet Printer Logo
Posted on Mar 02, 2011
What does canon pixma mp830 error code 6000 mean?
Anonymous
Level 1:
  • Contributor 277 Answers
  • Posted on Mar 02, 2011
Anonymous
Contributor
Level 1:
Answers
277
Questions
Helped
93496
Points
43
That is a line feed error (6000) It also should be flashing 3 times for this error on the on/off button.
This could be
1. Timing sensor unit QM2-2683
2. Timing **** disk film QC1-6229
3. Feed roller ***'y QL2-0925
4. Platten unit QM2-2923
5. Logic board ***'y QM2-3078
6. Paper feed motor QK1-1502
2 Related Answers
Fame_Guru
Sid
  • 483 Answers
  • Posted on May 02, 2009
SOURCE: I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
Robert Kitaji
  • 1335 Answers
  • Posted on Dec 19, 2009
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
2answers
1helpful
I have a Canon printer modal No MP830 AND I,m getting an error message 6A00.
the error code 6A00 means :
  1. an error occurred in the motor during the purg operation
  2. check the purg unit if it's broken replace
the picture of the motor: mabroukmedal_28.jpg
When switching on printer the very first time error code 6000 is coming up on the screen - printer pixma mp492. what does this mean?
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Error code 6000 seems to indicate <a itxtdid="24556202" target="_blank" href="/support/t4448972-today_bought_canon_pixma_mp492#" style="border-bottom: 0.075em solid darkgreen ! important; font-weight: normal ! important; font-size: 100% ! important; text-decoration: underline ! important; padding-bottom: 1px ! important; color: darkgreen ! important; background-color: transparent ! important; background-image: none; padding-top: 0pt; padding-right: 0pt; padding-left: 0pt;" classname="iAs" class="iAs">paper</a> jam - and often a very very tiny bit of paper in the machine that is difficult to find Try turning machine upside down and see if you can dislodge that way <br /> Have a look at page 620 of the online manual linked to below <br /> <i><b>6000 is displayed:</b></i> <i>If any object is placed in front of the machine, remove it.</i> <i>Open the Paper Output Tray gently, then turn the power off and back on.</i> <i>In other cases:</i> <i>Turn off the machine, and unplug the power cord of the machine from the power supply. Plug the machine back in and turn the machine back on. If the problem is not resolved, contact the service center.</i> <br /> For you information see below <br />Support site here <a href="http://software.canon-europe.com/products/0010816.asp" target="_blank" rel="nofollow">http://software.canon-europe.com/products/0010816.asp</a> User guide here <a href="http://software.canon-europe.com/software/0035429_0010816.asp?model=" target="_blank" rel="nofollow">http://software.canon-europe.com/software/0035429_0010816.asp?model=</a> direct link to PDF user manual <a href="http://files.canon-europe.com/files/soft35429/manual/Canon%20MP490%20series%20EN.pdf" target="_blank" rel="nofollow">http://files.canon-europe.com/files/soft35429/manual/Canon%20MP490%20series%20EN.pdf</a> <br /> <ul class="h_mi"> <li class="h_mi">If this solutions solves you problem, please do not forget to rate my solution.</li> <li class="h_mi">If not, then please comment back so I can help some more</li></ul></span>
6helpful
My canon pixma mp830 shows error code 5010. what
8helpful
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
3answers
Error code 6000 on canon pixma mp210 stops me from printing
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this failure. There are several explanations why Canon Printer Error 6000 will happen when you work with a Canon printer. One of the factors is that one of the most simple common explanations is where the paper feed tray is blocked by certain dust particles and bits of paper. Another reason for this is that the paper feed tray is not adequately connected to the printer. If there is a tonne of a print order.
Reasons that cause Canon Printer Error Code 6000:
1. The feed tray of the printer is improperly fitted.
2. A large number of documents near the printer.
3. The line feed is scratched or smeared.
4. Giving multiple paper print commands at once.
5. Faults within the sensor unit or in-line feed slit.
Follow Blog: Canon printer error code 6000
Thanks for reading.
7helpful
2answers
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
6helpful
4answers
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
old marine
old marine
ZJ Limited
ZJ Limited
