SOURCE: Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
SOURCE: Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
SOURCE: Mitsubishi TV; Model No. VS-45607
Straight from The Mits website
Intro Year:
2000
Chassis:
VZ8
Height:
48"
Width:
38 3/8"
Depth:
22 1/4"
Features:
The Silver Series includes Mitsubishi's most cost-effective projection televisions, yet they outperform by wide margins many of the more expensive models of other manufacturers. With their superb picture, wide assortment of inputs and features, and highly capable system remote control, the Silver Series sets new standards for the entire industry. These exceptional performance features include the following: DIAMOND VISION Optical System 3D-Y/C Comb Filter: Delivers crisp color separations and smooth picture texture. Dynamic White Balance: Ensures color accuracy at all brightness levels. Three S-video Inputs: One in front and two on the rear panel, allowing quick and easy connection of a high-quality camcorder or video game, while simultaneously providing connections for home theater system components such as a digital satellite system and an S-VHS VCR. Component Video Input: Provides the best possible picture quality from a DVD player. 64-Point Digital Convergence Adjustment: Easy to use and provides precise color alignments. 2-Tuner Multi-PIP with Split Screen. 5-Layer Multibrand Remote Control: Allows the operation of a satellite or cable box, a VCR, a DVD player, and an AV receiver-all from one keypad. Intelligent Room Illumination Sensor (IRISþ): Automatically reduces brightness and contrast for a more pleasant viewing experience in a darkened room. Weight (approx.) - 178 lbs Power consumption - 240W
