GE Advantium 120 Convection/Microwave Oven Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Advantium suddenly stopped working while using it. Acts as if it is unplugged. I checked the electric circuit and surgeprotector they are okay. It acts as if it blew a fuse, but I don.t know where to look!
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Mar 02, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541800
Points
28391
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
2answers
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
I have a GE Advantium SCA 200 oven that stopped working as we were cooking. the Breaker is OK and there is power to the receptacle. Is there a fuse in the unit that can be replaced without a technician?
Yes, it is a ceramic fuse inside the unit that can be easily purchased at your local Radio Shack. Take the original there and they will find the replacement fuse. Just unplug the unit before working on the electrical parts...
1helpful
Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Completely Dead
Since you've checked the external supply, the most likely causes would be the internal fuse, thermostat or thermal cutout. You can find exploded views and order parts here: http://tinyurl.com/gv383 For safety tips and disassembly tips, you can see my site via my listing here on FixYa: http://tinyurl.com/yzjozk
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
