Question about Hotpoint Washing Machines
I have a Hotpoint Ultima WMD 960 and it is flashing up F:05 what could be the prob;em and how do i solve it?
    Sergeant:
  • 196 Answers
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. F5 means pressure switch jammed on full. Hope this helps
Posted on Mar 02, 2011
Anonymous
SOURCE:
How do you change the drum bearing on a hotpoint ultima wmd 960
thier r 2 bearrings and a seal its called a bearring kit not very easy if u havent done it b4.
Jan 20, 2015 | Hotpoint Washing Machines
I have a Hotpoint WMD 960 Ultima. When I remove the washing after a cycle, the clothes are covered in dirty marks. can you tell me if this is something you can advise me about?
Look within the drum and observe if there is any dirt on it. Also check the quality of water. Check if there is any dirt /grease from the drum bearings due to failure of the bearings/seals.
Finally have the machine cleaned using good detergent cleaner , please check the link below for some tips:
http://www.espares.co.uk/parts/cleaning-products/dishwasher-cleaning/p/1423
Jul 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Our washing machine will not pump out and we have lost the manual
it should be at the back of the machine were the pipe for dirty water comes out there is a panel you can take off at the bottom of the machine when it is off you should see the moter and the pump were the pump is you and take off the black sump asmbaly and the filter should be there. hope this helps.
Mar 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
360 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
