SOURCE: message light
Store Messages are probably not recorded in the mailbox that is associated with the phone. Instead, they are probably in the General Delivery Mailbox or a mailbox associated with an ICD group.
Making it possible for the GDM to turn on a message waiting lamp is something that needs to be done when the system is first installed. Changing it later requires the entire voice mail system to be cleared, unfortunately. It is one of those things we always do for our customers, but most dealers do not.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: Can't turn off the blinking message waiting light
Unplug the phone from power for about ten minutes and see if that resets it..i'm not sure if that uses and adaptor for power... but be aware it also gets power from the phone line as well... so unplug that too.
Robert
Please take a moment to rate this solution.. thanks
SOURCE: Light won't flash when a message is waiting.
New phone/cable provider corrected the problem on their end. Evreything works at this time.
SOURCE: Message waiting light
Go into the voicemail, press 5 for message waiting notification options, press 1 for message waiting light status.
SOURCE: message waiting indicator
Try holding the mute/find handset button on the base unit for about 5 seconds and the light should stop flashing.
