Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
Hi there, we have a sony KV-30HS420 30 inch fd Trinitron that is blinking 7 times and then shuts itself off. We can turn it on again but this problem is understandably quite anoying. What do you think the problem is and How do I get this fixed?
    Brigadier General:
  • 8,909 Answers
There is a power supply fault causing the EHT to rise above 33KV.
High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that points the engineer in the right direction.
Posted on Mar 02, 2011
  • coreyduncan8 Aug 16, 2011
    K you are not helping. i need to find parts. or instructions on where to locate problem
6ya staff
SOURCE:
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kv34hs420 shut off itself
Hi:
If you count the number of error blinks when it shuts this will let you know the error code you are having. If the red led blinks say 6 to 7 times after shutdown then pauses and does it all over again there is a problem with the deflection board or D Boardas sony calls it, It is usually related to the two Power supply regulators IC's on the D-board.
Nov 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Tv turns itself off after 5 seconds...blinks 7 times?
Had the same problem. Unplug from wall for 36 hours and then it works.
Hp Sydney Aus
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
232 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
