McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
Anonymous Posted on Mar 02, 2011
I have a titan 8500 generator with 11 hp mcculloch motor. The motor pulls over easily with the spark plug out but with the spark plug in it is very difficult to pull over when the piston is on the comprssion stroke. what could be causing this?
Anonymous
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,949 Answers
  • Posted on Mar 02, 2011
Anonymous
Master
Level 3:
Renaissance:
Answers
1949
Questions
Helped
402985
Points
5880
Valves not opening properly
  • Anonymous Mar 02, 2011
    does this run? thats a big generator and i would expect it to pull hard. this size should be electric start, if it is get a battery and use it. If it does not run then i agree with shaneg8, but if it runs it is not a valve problem.
    very true craigss1013 and not geven that athough
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
2answers
Titan generator 8500
Try exciting the field with drill. Plug it in to generator pull the trigger and spin the drill backwards by hand.
1helpful
What spark plug does a mc collough 5700 11 hp generator take?
The manuacturers part number is: 030506Q01F910
Manual:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
Is there a brand.... on your current spark plug?
Most generators will do just fine with an NGK BPR5ES spark plug in most any environment.
Thanks for choosing FixYa,
Kelly
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Kelly
No spark to the spark plug when pulling the cord
First change the spark plug,if the problem persist,change the coil aka=spark plug cable and coil.
If you need more help come back.Post / thumbs / testimonial are welcome!
4helpful
2answers
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
3helpful
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
3helpful
2answers
I'm looking for A service manual for A McCulloch
This is an IPL for a Titan (11-600152-03):Please ensure this is your saw
http://www.ordertree.com/modelinfo/MCC/11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956/139.11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956.1.59.1.html
There are others here (IPL #11-600152-03 - just above this one. There may be others 12- etc.) :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This is an international collection of chainsaw enthusiasts, sellers/mechanics. There are McCulloch threads where repair and overhaul are discussed.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is where to request a service manual:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
one was requested here:
http://www.arboristsite.com/showthread.php?p=1342509&highlight=titan+50#post1342509
with no answer published. Good luck
Lou
1helpful
3answers
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
