SOURCE: The Radio,Cassette Player/Recorder. and CD Player all work. The Phonograph Does Not!
if it arrived by mail then the sender might have screwed the transit screws down to avoid damaging the phono , i am not familiar with memorex but if like most turntables there should be some big screw heads visible on the top of the phono or possibly even under the platter all you have to do is unwind the screws until the platter unit moves freely [you should be able to push it up and down a little bit ]
SOURCE: where can i find a repair manual or schematic to
your turntable rca Victor 1 emp 2kk is getting no sound because the electron tube 25L6 is shorted out, or not working...replace...take the 4 screws off each side of player lift out unit ..and replace tube.
make sure the unit is not plugged in when you do this.
Steveo
SOURCE: phonograph needle needed
check these guys out. They may be able to help. A little pricey, but they can rebuild from the ground up if need be.
http://www.phonophan.com/index.html
