The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
