Go to the main ps3 menu and go to settings(second from the left)
then sound settings(fourth from the bottom)
click audio output settings
select HDMI from the list
Also try blowing in the holes for the hdmi in both your tv and ps3 to clear out any dust
You need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
