Motorola Mobility H700 Wireless Headset Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hands free is on mute and won't come off mute .
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73178
Points
482
Hi, Motorola H700 Wireless Headset does not go on mute, it might be from the volume control of the Motorola H700 Wireless Headset or from the cell phone volume control.
You can use this quick guide to know how to increase and decrease the volume control.
motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Hope it helped.
Have a nice day.
Why can't people hear me talking when I try to use my TX 550 hands free device. Microphone is not muted.
Hands free needs to be checked especially the microphone.
Suspect connecting cable loose or disconnected internally or hands free board bad/defective (microphone part)
How does the mute function work on the Kenwood KDC-5043U. Where do I connect the brown mute wire? I have a Samsung Galaxy S5
If you were installing a separate hands-free phone kit along with the Kenwood head unit, you'd connect the Kenwood mute wire to the muting output on the hands-free kit. This allows the other device to mute the audio from your radio while you're using the phone. If you don't have a hands-free kit, you wouldn't connect the Kenwood's mute wire to anything at all.
1helpful
Brown mute wire for new ken wood in 2002 rodeo, does it go with illumination wire, green/red or red/green?
Hi, i'll need a bit more info to be able to give you an opinion , am i correct in assuming the "new kenwood " is a radio/cd player ? If so do you have a car phone or a hands free kit for your mobile/cell phone ? Assuming the kenwood is a radio the mute wire has to be connected to the car phone/mobile hands free kit , this is usually described in the phone installation directions , how the mute system works is when you recieve a call the signal is sent via the phone system to the radio , which is where the mute wire comes into use .If you have either of the phone set ups i've described post back with there details , make , model etc ,if you do not have this type of system and are using an ear piece then the mute funtion can't be used , i hope this is of some help to you
My mercedes e class 54 reg had power down my stereo I change the fuse power came back but it shows mute mode does not give any sound when my engineer put on his computer its works then mute again
Hands free mute is caused by a switch grounding the radio , if you have a hands free kit it is permanently grounding causing MUTE , if it's a short to ground check wiring loom in car always test loom with a multimeter
2helpful
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
'Yellow Wire - Stereo Connection???'
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
2answers
CK-7w mutes stereo
if cutting the power to the kit dont work try removing the radio and removing the yellow wire from the back for the radio (the one coming from the junction box of the kit). that should get the radio/cd working properly. inspect the wire and make sure its not earthing anywhere behind the dash. radio isnt realy that easy to take out if you dont know what your doing.
H500 mute problem?
I haven't heard of this before. Turn off it off and remove the pairing from your phone.
Turn it back on and pair it up again. Make sure you enter the passcode (usually 0000). That should fix it.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
