You can use either Walkabout Transfer or Walkabout Write found here:
https://isupport.nuance.com/OA_HTML/csksxvm.jsp?nSetNumber=13097
Also, if you connect the portable via USB to your PC, it'll connect just like a USB memory stick and you can use Windows Explorer to transfer your dictation from the 'DSS' folder.
First, you will want to BACKUP ALL of your programs.
Since you did not upgrade to VISTA, you will LOOSE all of your programs when you upgrade to Windows 7, so be sure to backup all of your programs and files.
If you wish, you can use an external hard drive and a program called WINDOWS EASY TRANSFER to make this task easier.
See the link below for this FREE program.
Now, for the fun part! Insert the Windows 7 disc into the computer and start or restart the computer.
Follow the onscreen instructions to completely install Windows 7.
You will now need to reinstall each of your programs.
If you used Windows Easy Transfer, you can use the list of programs that it prints out to be certain that you reinstall all of your programs.
Hope this helps.
