Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LiftMaster Gargage door opener problem
Whenever I close my garage door it goes to the bottom of the door and then opens itself back up automatically. Any suggestions?
Thank you.
  • Anonymous Jul 29, 2008
    Same issue the door keeps open up when it reaches the bottom. One of teh sensors lights is orange and cannot seem to align it to get a green light.
  • Anonymous Oct 18, 2008
    door won't stay in adjustment
    Novelist:
  • 158 Answers
The door obstacle detector(reversing switch) needs adjustment, or the down limit sensor needs adjusting, or one of the lift springs is loose or broken. First, remove power from the opener, pull the red door release rope, and try to lift the door up manually. You should be able to lift it all the way open with litle effort. If it opens ok, pull the door down about halfway and let go. If it is properly balanced, it should stay where you left it. If the door fails either one of these tests, it needs spring replacement or adjustment. If the door moves ok, refer to your owners manual on how to adjust the reversing switch, linit switches, and photocell sensors at the door bottom.
Posted on Aug 02, 2008
6ya staff
SOURCE:
The garage door seems to pick up speed the last two feet when closing then it automatically goes back up
Sounds like a spring tension problem. Best toi call a professional as retensioning the springs can be a source of serious personal injury.
Sep 12, 2014 | Sears Craftsman LiftMaster Chamberlain...
Light flashes on gargage door and it will not close, but it opens
Maybe it's the safety device that prevents the door closing if there is an obstruction. Many of these have a reflector mounted near the floor on one side and an infrared light on the other side. If either end it obstructed, the door won't close.
Oct 02, 2012 | liftmaster Chamberlain Garage Door Opener...
The light on my garage door unit goes off and on by itself. when the light goes off the garage door stops opening or closing
It sounds like you have something obstructing the safety light that runs across the bottom of the door. If this light is obstructed, it will stop the door action and blink the light off and on to let you know that is the case. Sometimes a cobweb or leaf will be enough to cause this. Also clean off the bottom of the door which may have cobwebs hanging from it that would cause the obstruction.
Jan 22, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door opening when hitting close button
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit. Tweak them a little if necessary.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you reset your codes in the liftmaster/remotes. ours goes up and down varies times of the day,found out our neighbors remote is doing it. all new houses where we live have the same garage door...
press and hold learn button for 10 seconds and then reprogram your remotes by pressing and release learn button and then press and hold remote button. The big lightbulb on the motor will flash once.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener problems
We had the same problem.  open the unit and checkt the connections.  we had a few loose wires and every time there was a vibration whether a low flying plane or a truck nearby the door went up.  My husband found a few of the wires had loosened up.
Jan 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener
IF IT HITS THE FLOOR AND GOES BACK UP. YOU NEED TO ADJUST THE DOWN LIMIT.
IF IT GOES BACK UP BEFORE HITTING THE FLOOR YOU NEED TO ADJUST THE SENSITIVITY OR THE SAFETY EYES.
TRY THE DOOR MANUALLY AND MAKE SURE IT WORKS SMOOTHLY.
Sep 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Feb 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
349 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
