Sounds as if the drain tube from the dehumidifier to the collection bucket may be clogged. Turn the unit of, unplug it and remove the bucket. With a flash light, look up into the rear of the cabinet where the bucket was. You should see a drain hole or short section of tubing. If you can see a clog, carefully remove it. If you can't see one. it may be further up the tube. Use some type of wire that is flexible, but yet firm enough to run up through the tubing or hole. Very very careful when you do this, as you don't want to puncture or damage anything.
The other option, if you have an air compressor is try blowing the clog back through the system, using fairly low pressure.
If all else fails, contact LG Customer Service (800) 243-0000
Testimonial: "I think this worked. Used two plastic zip ties snapped together and when I got around the 90 degree bend in the pipe water came pouring out. Thanks."
